  • Гараж
  • "Вечные" вопросы. Инструмент, методики.
F.A.Q. набор спец. инструментов для ремонта Вольво (на примере xc70 2.5t 2004)
  • Автор темы skydriver
  • Дата начала 20 Ноябрь 2021
skydriver
20 Август 2018
Псковская область
Денис
  • 20 Ноябрь 2021
08: 0313 - Personal tools for technicians
Сьемник масл.фильтра JTC1522 за 700 руб.
Personal Hand Tools, Service & Repair
Tool No.descriptionNumberPicture
Combination Wrench 6-22, 24mm1 of each
Combination wrench 8-19, 21mm Gearless or ratcheting.1 of each
Flex-Head wrench 6-7, 8-9, 10-11, 12-13, 14-15, 16-17, 18-19mm1 of each
Adjustable wrench 4" and 6"1 of each
Allen wrench set (Ball end) 1,27→10 mm Note! Must include 7 mm1
Torx wrench set (Ball end), T9→T401
Ratchet 1/2"-drive
Ratchet 3/8"-drive
Breaker bar 1/2"-drive1
Torque Wrenches 3/8"-drive 6-50Nm (with changeable head, ratchet, open ends, box ends)
Torque Wrenches 1/2"-drive 40-200Nm (with changeable head, ratchet, open ends, box ends)
Adapter 1/2"-drive internal, 3/8"-drive external1
Adapter 3/8"-drive internal, 1/2"-drive external1
Extensions 1/2"-drive
Approximate length 50, 75, 120, 250, 500mm
Extensions 3/8"-drive
Approximate length 75, 120, 245mm
Extensions 1/4"-drive
Approximate length 250mm
1 of each
1 of each
Extension-Friction Ball 1/2"-drive
Approximate length 50, 120, 250mm
Extension-Friction Ball 3/8"-drive
Approximate length 75, 145, 245mm
1 of each
1 of each
Socket set 1/4"-drive1
Deep impact socket 1/2"-drive 19, 21mm1
Universal socket 3/8"-drive, 10→19mm1 of each
6-point Socket 1/2"-drive, 10→22, 24→30, 32, 34, 36mm
6-point Socket 3/8"-drive, 7→14mm
1 of each
1 of each
12-point deep socket 3/8"-drive, 10→17mm1 of each
Spark plug socket 3/8"-drive 16, 21mm Magnetic or rubber holder1 of each
Impact universal joint, 1/2" & 3/8"-drive1 of each
Socket 3/8"-drive, hex5→8, 10mm1 of each
Magnetic High performance bits holder socket, 3/8"-drive1
Socket external Torx®, 3/8"-drive T15, T20, T25, T27, T30, T40, T45, T50, T551 of each
Screwdriver, 2.5mm flat tip
Screwdriver, 4.0mm flat tip
Screwdriver, 5.5mm flat tip
Screwdriver, 8.0mm flat tip
Flexible nut driver 6mm
Flexible nut driver 7mm
Nut driver 8mm
Nut driver 10mm
Torx screwdriver T10, T15, T20, T25, T27, T301 of each
Torx screwdriver T4-T91 of each
Screwdriver, magnetic 1/4" bit holder1
Screwdriver, stubby magnetic 1/4" bit holder1
Bits ratchet, 1/4-drive1
Torx® Bit Kit, 1/4"-drive (short/long model)
Note! Must include Tx27 Phillips® Bit kit, 1/4"-drive (short/long model) Flat Tip Bit kit, 1/4"-drive
Scissors1
Nut pliers1
Combination pliers1
Needle nose pliers1
Needle nose pliers, 45° angle jaw1
Universal pliers, small & medium1 of each
Side cutter small & large1 of each
Hose Pinching Pliers2
9512619Pincers (double end)1
Pliers for bulbs1
Clip remover1
Utility knife with snap off points1
Knife1
9814071Trim pad tool1
Blade Scraper
Extra blade
File, mill type (for rough filing on brake callipers)1
File round, medium.
Approximately 8mm of diameter
Multi-Cut flat file (second) Length.6"-8"1
Plastic mallet Approximate weight 300gr1
Cirve cross pein hammer Approximate weight 300gr1
Drift punch diameter 3→6, 8mm
Drift punch diameter 4mm, extra long
Drift punch diameter 6mm, extra long
1 of each
Flat cold chisel Approximate length 120, 200mm1 of each
Centre Punch (large)1
Automatic centre punch1
Putty Knife/scraper (steel)1
Pry bar
Length 400-500mm
Tape measure 2m1
Feeler Gauge 0.05-1.0mm1
Vernier calliper1
Gauge, Tread Depth1
Air impact wrench, 1/2"-drive1
Air Ratchet, 3/8"-drive short model1
Airgun1
Cordless Screwdriver 1/4" slip chuck
Extra battery (Cordless Screwdriver)
Ear Protectors1
Safety glasses1
Oil can1
Wire brush1
Torch1
Telescopic/flexible mirror1
Magnetic pick-up rod, telescope type1
[automerge]1637436482[/automerge]
Всем привет!
Предлагаю потихонечку создать русско-язычную версию набора, желательно с фото
если кто захочет помочь - велкам в топик,а потом результаты соберу опять в таблицу
Реакции: liner
1 из 2 Вперёд Last
16 октября 2017
Пенза
Пензенская область
Артем
  • 21 Ноябрь 2021
  • #2
А поясните, это имеется в виду какая-то специализированная подборка оригинальных инстументов, или как?
А то я вот таким пользуюсь, и как бэ норм)))
Mistel
1 Ноябрь 2015
C70 II
& V90 II
Максим
  • 21 Ноябрь 2021
  • #3
Для рядового юзера и работ типа снять поводки дворников или даже поменять колодки подойдёт. Но выше имеется ввиду дилерский инструмент для ПОЛНОГО перечня работ с автомобилем включая ремонт подвески, двигателя и т.п.
Реакции: skydriver
6 февраля 2010
S80 I
Антон
  • 21 Ноябрь 2021
  • #4
Ratchet 1/2"-drive
Ratchet 3/8"-drive
1 of each
1 of each
1 of each
1 of each
1 of each
1 of each
Nut driver 8mm
Nut driver 10mm
Scissors1
Nut pliers1
Combination pliers1
Needle nose pliers1
Pliers for bulbs1
Clip remover1
Knife1
Blade Scraper
Extra blade
File round, medium.
1 of each
Pry bar
Length 400-500mm
Tape measure 2m1
Vernier calliper1
Gauge, Tread Depth1
Airgun1
Ear Protectors1
Safety glasses1
Oil can1
Wire brush1
Torch1
Всем привет!
А зачем и кому это вообще нужно? Думаете кто то будет инструмент по списку этому покупать?
Реакции: Mike15
skydriver
20 Август 2018
Псковская область
Денис
  • 21 Ноябрь 2021
  • #5
у меня такой же, но много было головняков что не подходит то одно то другое
я бы купил, хороший и подходящий инструмент - пол дела
если он никому не нужен, зачем его в виде тогда публиковали..
Mistel
1 Ноябрь 2015
C70 II
& V90 II
Максим
  • 21 Ноябрь 2021
  • #6
Его стоимость будет как пол тачки Оно вам точно надо?
Реакции: Mike15
Mike15
18 января 2015
Михаил
  • 21 Ноябрь 2021
  • #7
Это дилерский инструмент, состав которого подобран в соответствии с официальными инструкциями. Чтобы ремонтировать машину, совсем не обязательно иметь всё то, что указано в подобном перечне. Тем более, что фактические процедуры по снятию/установке в жизни могут отличаться от официальных, соответственно какой-то инструмент может оказаться лишним или, например, наоборот, данного перечня может не хватать. Ко всему этому можно добавить и то, что дилерский инструмент стОит, как тут правильно сказали, немалых денег, при этом к большинству можно найти достойные аналоги. Зачем мне съемник масляных фильтров volvo 9995679 за 3300 руб, когда я могу купить такой же JTC1522 за 700 руб..
Реакции: Mistel, Fatto и skydriver
6 февраля 2010
S80 I
Антон
  • 21 Ноябрь 2021
  • #8
Там написано для кого эта информация - для профессиональных техников, а не для автолюбителей, которые колодки сами меняют, им это точно не нужно. Достаточно хорошего набора инструмента + постепенно покупаются вещи под конкретные задачи. Полный комплект инструмента будет стоить очень неплохих денег.
Реакции: frozen и skydriver
skydriver
20 Август 2018
Псковская область
Денис
  • 21 Ноябрь 2021
  • #9
масляный фильтр я вобще отверткой и молотком пробиваю и откручиваю))
но это неправильно же
идея топика как раз в том не чтоб оригинальный инструмент купить, а подобрать более дешевый аналог(посмотреть фото инструмента и т.п.)
6 февраля 2010
S80 I
Антон
  • 21 Ноябрь 2021
  • #10
На машине из профиля ? Хорошо зарабатываете, если можете каждый раз новый корпус покупать за два косаря )))
Реакции: Tarantas, plutos, AlexV8 и 2 других читателей темы
skydriver
20 Август 2018
Псковская область
Денис
  • 21 Ноябрь 2021
  • #11
ой нет - это было на форде старом, напомнили))
тут просто руками...
6 февраля 2010
S80 I
Антон
  • 21 Ноябрь 2021
  • #12
Это как ? 25 н*м руками ? ))
skydriver
20 Август 2018
Псковская область
Денис
  • 21 Ноябрь 2021
  • #13
да, еле-еле, по чуть чуть...а вообще да,чуть перелом на запястье старый не открылся(
вот знал бы про jtsc за 700р и проблем бы не было
для того этот топик и создавался!
пс а как(чем) вы 25нм на закручивание выставляете фильтра?
6 февраля 2010
S80 I
Антон
  • 21 Ноябрь 2021
  • #14
пс а как вы 25нм на закручивание выставляете фильтра?
динамометрическим ключом . Он в Вашем списке кстати есть .
skydriver
20 Август 2018
Псковская область
Денис
  • 21 Ноябрь 2021
  • #15
не совсем понял как на фильтр поставить этом ключ - вопрос в этом
а...через спец инструмент типа jtc?
6 февраля 2010
S80 I
Антон
  • 21 Ноябрь 2021
  • #16
Обычно его тянут ключом даже сильнее, вообще удивлен что его можно как то руками открутить.
skydriver
20 Август 2018
Псковская область
Денис
  • 21 Ноябрь 2021
  • #17
я его всегда руками закручивал и откручивал - уже 3 шт заменил
6 февраля 2010
S80 I
Антон
  • 21 Ноябрь 2021
  • #18
Да через ключ само собой, у меня руки не стальные что бы его без ключа тянуть )
skydriver
20 Август 2018
Псковская область
Денис
  • 21 Ноябрь 2021
  • #19
кстати и без 25нм затягивается руками нормально - ничего не течет
6 февраля 2010
S80 I
Антон
  • 21 Ноябрь 2021
  • #20
Течь и не может, там уплотнение такое что момент не принципиален, но есть технология, а после сервиса его руками точно не отвернуть.
Реакции: skydriver
1 из 2 Вперёд Last
  • Гараж
